Abs Help
    both under rear seat
    • fluk3
      • Mar 2008
      • 146
      • Home: Denmark
      #32
      problem is resolved.
      I changed the block in the engine compartment where the pump for the brakes also sit, it must make some form of back pressure and if it is not making enough press reports the error when you start driving
      got some hints from an audi electrical expert here in Denmark
      and the car went straight through the inspection day
      nice so I can soon get number plates on it
      Once an audi s2 coupe on the streets again
      for the first time since the car was expoteret from germany in 3/27/2002
      cheers christian bogh
      • predding
        • Aug 2009
        • 132
        #33
        Christian
        Can you tell me exactly where this block is (or post a picture) as I am having exactly the same problems with my URQ 20v RR after refurbishing all my calipers, fitting new seals, and new ablative caps on the sensors plus the brake pressure id porr despite new Goodridge hoses all round and new O rings etc in the pistons and new fluid (all bled system - no air)
        My car has not been used much in the past 5 years so thinki9ng this could also be a componet failure in the system
        Thanks
        Paul
