Agreed! There does not seem to be any reference to these discs.
Back to square one! Unless those brackets are to fit those discs you will be no better off. Surely the retailer must know the application of their products!
Jade, its not ideal but you could surely just reuse those VRS carriers by using a washer to move the bracket inboad and two spacers or a single strip of material to move the caliper out the 4mm required assuming they are 330X34mm. Unless you can obtain any replacements seems a bit pointless making bespoke brackets as once the discs are worn out there will be no replacements available!
Or sell those 322mm VRS brackets and get some made to the correct spec. Shouldn't be too dificult to calculate the dimensions necessary.
Don't get me wrong I will not save money on behalf of the safety so if that is the issue then it's new pads for sure. It's just that when reasoning on it I don't really see why 70%used pads should not be possible against new discs when they are in ok condition. It's the pads that will bed in with the discs anyways I guess.
Not for the performance but for the looks
all parts have arrived and I will try to assemble it tonight. Got a bit dissapointed when I noticed that the stock 996 bolts for the calipers seems to have other threads than the adapter I bought. Anyone got a tip on howto measure inside threads? Easy to measure the bolt..
