996 turbo / GT3 calipers - which pads? r90 DS2500 issues?
    Which pads are recommeneded for daily driving for a 996 turbo calipers?
    torn between textars and ds2500, what is not helping is Ds2500 are not r90 rated so I'm not sure on the legality of them on the S2 even though the car is pre 1999 the calipers are 2000 onwards ( real grey area )
    Phoned questmead and the ceramic pads they had were over £200 so they are firmly ruled out.
    What have other members used?
  • Big Lee M
    • 2571
    To be honest a pad of that size is going to be good in standard form that's why they put them in the GT3. Unless your doing sprinting or a lot of track days I'd go for textar.
    Just some finishing touches to do now
    • Le S2 Audi
      • Jul 2009
      • 3805
      I have textar's on my Coupe with 996 C2/C4 standard calipers... And I hate them, hence why I did the group buy on the DS2500's.
      S2 Spike has fitted them to his upgraded coupe too and he seem's to be very happy with 'em... but he is compareing them to standard calipers with Red stuff pads and slotted disc's so there is bound to be a big differance...:mischeif:
      I can't comment on the DS2500 as I missed out on this group buy as the supplier & Factory has run out of them...
      New S2 - S8 & RS2 -RS6 Keyrings
        Have you got a confirmed delivery date for the pads in the group buy? thats whats putting me off the GB at present.
        I know about DS2500 in 996 boxster calipers as I had them in my old S2 Coupe.
        They sold me the car when Alistair C did a brake test and sent me and my friend flying, I had read on S2central stock brakes were rubbish not the porsche calipers and ds2500 they will send you to hospital
        • Le S2 Audi
          • Jul 2009
          • 3805
          They should be here this month, but I am waiting to hear back from CS about them..
          • lind4hl
            • Jul 2008
            • 2465
            Textar and EBC makes me shiver..
            Ferodo, Hawk or Carbotech is the way
              Hawk and carbotech are track oriented already looked into them, need street pads with cold bite
              • lind4hl
                • Jul 2008
                • 2465
                carbotech ax6 mate
                  pagid RS series are supposed to be excellent but IIRC pricey?
                    Too pricey, it all adds up when your doing a complete conversion, I might give carbotech a ring to see their prices but at the moment pagid, ate, textar and at the top end at £100 are DS2500
                      Has anybody looked into the ECE R90 issue with DS2500 pads?
                      • Le S2 Audi
                        • Jul 2009
                        • 3805
                        What is that? and maybe I can find out!!
                        • madpugger
                          • Sep 2007
                          • 1901
                          I use EBC yellows and I find them perfect. I know a lot of people hate them, and being Scottish I should hate them too (joking guys!) but they have excellent cold bite and I have used them at the 'ring, on the ring GP circuit and Knockhill and they were superb, outbreaking lotus 2 11s and pretty much anything else on track, no fade what so ever.
                          Le Mans 2012
                          Nurburgring 700
                          1995 S2 Avant
                            http://briskoda.net/forums/topic/155...day-only-pads/
                            OKTOGEL MERUPAKAN WEBSITE HONGKONG LOTTO RESMI YANG MENGHADIRKAN BERBAGAI PASARAN HONGKONG LOTTO TERLENGKAP DI INDONESIA JAMINAN JACKPOT TERBAIK HARI INI
                            "Using Ferodo DS2500 pads on a vehicle which is on the public highways is now totally ILLEGAL im afraid and has been since 1999 - they are classed as a true track pad !
                            Here's some more info for you;
                            ECE Regulation 90 (R90)
                            European legislation came into effect September 1999 titled ECE R90 that stipulates that all brake pads sold for use on vehicles manufactured after this date must be tested and comply to R90 standards.
                            This test which involves taking each homologated vehicle used on the public roads within Europe and comparing the front and rear brake performance with the original parts to those of aftermarket offerings, has closed the door to cheap and nasty imported brake pads. The test includes cold and hot brake friction analysis, and if a part has been approved to R90, it can be safely assumed that the product is equal to or better than original equipment product. The brake pads are then marked with an R90 code number and a country code in a circle such as E1 for Germany or E11 for UK which signifies where the testing has been done.
                            EBC Brakes does all of its testing at the VCA (Vehicle Certification Agency) test facilities at MIRA in the UK. 'MIRA' is the Motor Industries Research Association who have a high speed test track for conducting these tests, which EBC Brakes uses on a regular basis.
                            Factory approval is part of the R90 process which involves engineers inspecting and accrediting the factory manufacturing the product before approval is given.
                            Ferodo technical actually told me today the following;
                            ""The use of Ferodo DS 2500 pads on ANY car ( apart form a certain Aston Martin, whos use of this pad got homologation, due to the stopping power required and so therefore became the OE part! ) is totally illegal for road use and apparently there was a famous case not so so long ago where Devonshire Police asked Ferodo to identify the pads fitted in a highly tuned Corsa involved in an RTA where a woman died. The driver of the Corsa was prosecuted for using these pads !""
                            Its not worth the risk !
                            They recommend you use instead the Ferodo DS Performance Fast Road pad ref: FDS 1259 available from most good Ferodo Stockists throughout the UK
                            • s2avant
                              • 2426
                              Why would it be an issue? I can't see that R90 makes a blind bit of difference to what we would choose to fit on our cars
                              No disrespect to you but unless you're going to use your brakes hard why not just go with the cheapest option? You aren't going to notice big differences unless you are using them properly and if your doing that on the street then more fool you. Track use is another issue all together.
                              Personally I have tried DS2500 and they actually fell to pieces. Braking performance wasn't noticeably better than stock either. Maybe I had a bad set but I won't be using them again. I now run OE pads on my brake setup and have never had issues with brake wear etc.
                              Ben
