Exception to regulation 4
5. Nothing in regulation 4 shall be taken to apply in relation to replacement brake linings for
fitting or fitted to a relevant vehicle which was first used before 1st September 1999, provided
that the replacement brake linings are not such as to cause the vehicle to contravene the version
of the Braking Devices Directive that was applicable to it when it was first used.
How are they going to prove that your calipers are newer than your car? If you hit someone else then it is your fault end of story, your choice of pads is irrelavent. In the event of an accident they would only go to all the effort of checking what components are fitted if they couldn't find some other way to blame you. If you hit the other car then it's pretty obvious who is at fault. The urban legend about a corsa driver being prosecuted for having DS2500 pads in his car is rubbish. Do you really think the police were bothered about what brake pads he was using when he had KILLED someone?
Ben
