996 turbo / GT3 calipers - which pads? r90 DS2500 issues?
  • Le S2 Audi
    • Jul 2009
    • 3805
    Oh... OK..
    I have just asked the question..
    Lets see what they have to say!!
    I Guess You would have to be very unlucky for 'em to just pick on the pads... what if they were fitted by a garage???
    New S2 - S8 & RS2 -RS6 Keyrings
    • GazzaG60
      • 4133
      if the parts are not approved its not road legal. simple as that.
      thats the way i take it anyway.
      i have a good reason for using good pads though. i dont want to crash into the car in front but the car from behind is less of an issue to my pocket.
        R90 is bloody stupid as pads have to be within -15 to +15% working of the original pad where the DS2500 exceed the +15%
        As 1st post, real grey area as our cars are pre 1999 but the calipers are not, I can't find anything in relation to if it affects parts going from a newer car to an older car
        For now i've decided to use Pagids and will ask around and use the DS2500 next time around if I can satisfy myself it's safe to use.
        • GazzaG60
          • 4133
          its worth the thought i agree.
          if the brakes are so good somebody runs in the back of you. is it your fault for installing pads too good for teh road?
          • Le S2 Audi
            • Jul 2009
            • 3805
            #20
            What about fitting ceramic's then???
            Don't they stop you even quicker than normal brakes??
            Seems a daft rule to me...
              As long as they have the R90 logo on the back they are fine.
              I really hate these stupid European laws that have come in, bring back Thatcher!
              • GazzaG60
                • 4133
                ceramic pads wont stop you faster. they have a higher temp co-efficient. they will nothing at all for stopping till warm.
                the 15% factor gets around this issue.
                we also have made this issue worse by fitting bigger discs.
                by doing the upgrade you take away the instant stopping as they take longer to get warm. using a pad thats not so sporty may get around this but there was little point in the upgrade for stock temperature brakes.
                • Bram
                  • Aug 2006
                  • 2582
                  I run the DS2500 for some time now on the GT3 360mm setup, and find them much better braking then the Textars, even cold. Also they do not make noise compared to the Textars. My MOT garage never checked the brake pads. With the brake test they say, the more brake power the better! So this might be a UK thing, not EU legislation.
                    R90 is a European law read the links in my previous post, definately not a U.K thing. MOT tester could only check if he removed your pads how many would do that? however if they are not road legal and you have an accident and the police become involved this is what people should be concerned about.
                    As said it only applies to cars made after 1999 but the grey area is cars made before 1999 with post 1999 car parts and brake pads
                    A lot of people are running them without being aware of this, I was on my old Coupe
                    google ds2500 and road legal and look at the chatter out there, all because they perform 15% better than O.E
                      Interesting post on Audisrs on the 10th May
                      Also on Ferodos site it says "All our pads are R90 compliant and go through extensive research" which is enough for me
                      This ONLY refers to their 'Premier' range - NOT DS2500....
                      But fear not...well I did a bit of research into this, with the help of BG Developments (AP's premier supplier)...and what we discovered was that Reg90 covers vehicle homologation...but crucially where calipers/discs have been fitted as upgrade (like AP for example)...this homolgation doesn't apply. And I was told " Pads sets which fit brake upgrade kits cannot be homologated because there is no OE equivalent system with which to compare them."
                      Whether this is absolute or not, I don't know....
                      Also - this has been law for nearly 10 years now....
                      Here's the relevant extract:
                      Brake linings for relevant vehicles
                      4.—(1) Subject to regulation 5, no person shall—
                      (a) supply or offer or agree to supply for fitting to a relevant vehicle;
                      (b) expose or possess for supply for fitting to a relevant vehicle; or
                      (c) fit to a relevant vehicle,
                      brake linings which do not meet the requirements specified in paragraph (2)(a) or (b).
                      (2) The requirements are—
                      (a) that the brake linings—
                      (i) have been type approved in accordance with the requirements of the Braking
                      Devices Directive;
                      (ii) have been marked by the manufacturer in accordance with the requirements of
                      paragraph 3 of Article 6 of the Framework Directive; and
                      (iii) are marked and packaged in accordance with the requirements of point 4 and
                      point 6 of Annex XV of the Braking Devices Directive; or
                      (b) that the brake linings—
                      (i) have been approved in accordance with paragraph 4 of ECE Regulation 90.01;
                      and
                      (ii) are marked and packaged in accordance with paragraph 6 of that Regulation.
                      Exception to regulation 4
                      5. Nothing in regulation 4 shall be taken to apply in relation to replacement brake linings for
                      fitting or fitted to a relevant vehicle which was first used before 1st September 1999, provided
                      that the replacement brake linings are not such as to cause the vehicle to contravene the version
                      of the Braking Devices Directive that was applicable to it when it was first used.
                      I'm going to phone Ferodo
                        I'm really not sure a consumer could be expected to understand and abide by this regulation, i'm sure only a fractional percentage of end users will have even heard of it before.
                        The responsibility to advise on suitability / legality for road use surely has to lie wiith the retailers in this scenario.
                          I looked into this and this is what Camskill say
                          Customers should be aware that these are a Racing Compound and as such that we do not warranty these pads for use on the road.
                          In otherwords it is YOUR risk to use on the road.
                          • s2driveruk
                            • 12696
                            is this thread serious or have i got my dates wrong and its April 1st?????
                            Get OEM if you don't intend to give the car some beans regularly as although i find the DS2500's work well from cold and lets face it the avant has more mass in the first place to stop, they really come into their own when well up to temperature. if you are just going to cruise round then i doubt you will feel them work too much better than stock items. regards R90....who has ever sited or waived a piece of paper infront of anyone using them...never. Mine passed its MOT with new pads and discs the other day....its obviously produced enough cold friction to pass the brake test so i fail to see the issue?
                            Go with what pad you want to run...i havent heard of too many cases of people burying the nose of an s2 into something else cos the initial bite was poor on any ds2500
                            1992 3b S2 Coupe
                              Why would it be a joke?, I never mentioned MOT Bram did in confusion as the thread was never about the MOT.
                              • Le S2 Audi
                                • Jul 2009
                                • 3805
                                #30
                                I am due a reply from the Ferodo supplier, he is doing me a full and detailed reply, but he keeps getting interupted...
                                Will post it as soon as it arrives.
