Using TT Calipers ?
  • BRY
    • 3755
    Don't skim the disc faces by 2mm either side.
    You will die.
    • bikerjim
      • Feb 2008
      • 1028
      lol, yeah thought that was a bit excessive
      • sam80quattro
        • Oct 2006
        • 1496
        i tried a4 286mm calipers and discs on my 90q hubs and everything lined up perfectly, only difference being the fact that the discs are different pcd's, pretty sure you can upgrade the a4 brakes using passat/a6 etc 312mm carriers, so if you were to get a 312mm setup from an a6/passat and get the discs redrilled to 4x108 everything should bolt straight up.. i think lol might be worth looking into that
        • bikerjim
          • Feb 2008
          • 1028
          Im going 5 stud hubs sam Got the 312mm calipers/ carriers(from a tt), using s6 discs that are 314x30 where the tt ones would of been 312x25, this makes the discs too wide for the pads and calipers
          • sam80quattro
            • Oct 2006
            • 1496
            not worth selling the tt's and buying a6/passat 1s? to save a headache? best to try them first though lol
            • bikerjim
              • Feb 2008
              • 1028
              I thought the calipers were the same throughout just the carriers changed?? hmmm
              • sam80quattro
                • Oct 2006
                • 1496
                that does sound right, but if you could get a lend of a passat carrier and disc to try it, and it all fits, the woohoo
                • bikerjim
                  • Feb 2008
                  • 1028
                  good point, I think there might be one i a local scrappy. I'll go check 2mora
                  • bikerjim
                    • Feb 2008
                    • 1028
                    I think I have found a solution. There are a set of discs off an audi A6 (later model) that are 314x25mm part No. 4F0 615 301 D
                    Found info here - http://www.audifieber.de/audiforum/t...E57-314x25-P-P
                    Gona get a set of these discs and see how I go
                    • sam80quattro
                      • Oct 2006
                      • 1496
                      ive got a feeling that the discs are a different offset... i bought a pair of porsche calipers and 330mm 2 peice discs that where a straight fit on a s3 but when trying them on my 90 i had to machine quite a bit off the carrier so it moved outwards towards the wheel and then it sat over the disc properly...
                        Skim the pads and change them more often
