I just use "Coppaslip" on the backs and edges of the pads. Threw the anti squeel plates away when the sticky stuff gave out, they squeeled with them in anyway.. Well, more of a droning noise as said, which goes away breifly when you dab the brakes, have had no problems for ages now thou using copper grease.
996 Had enough!
I have an awful squeal on braking in the RS2.
I don't know if it's needing new shims, cleaning out brake dust, or making sure clearences etc are all as they should be.
One thing's for sure, I definitely want to get it fixed!John Bowlerwell
Electronic Engineer
Present:
Nogaro Blue RS2 - TOE
Previous:
Kingfisher Blue S2 - UAA
Volcano Black RS2 LHD - DEXComment
If you don't have these, it is worthing the expense of getting and fitting them. Worked for me and transferred to new pads if careful.
Once it's fixed, the financial pain of the shims will soon be forgotten.
Obviously making sure the other items already mentioned earlier in the read are also not contributing factors.
Well worth seeing it through as the brakes are a very worthwhile upgrade. Tried and tested also, so it's got to be fixable it you keep at it.
Keep the thread updated, the forum's here to assist.
Kind regards.Comment
get some of this stuff...its fantastic. http://www.camskill.co.uk/products.p...m20b918s2014p0
I have to say though, using 996's means there is some routine maintenence that needs to be completed every few months to clean and lube everything....time invested but keeps them running sweetly i found.sigpic
1992 3b S2 CoupeComment
No but way would need to remove some off the outer diameter?Comment
Old greymatter remembered about the RS2 disc size being 304mm rather than 314mm and some of the original conversions using RS2 carriers had the disc OD reduced. A newer kit with 996s might be different; seemed worth asking though, so we know what's what.Cheers'en, AndyC
Good chance it will be the stainless shims in the calipers, The older RS2 type calipers are prone to corrosion behind the shims, This stops the pads being retracted, Anti squeal shims are the same as those pictured above,
FYI, another 2 noggy RS2's in the Falkirk area1995 RS2 Nogaro
1971 Lotus Elan Sprint
1974 Lotus Elan+2S 130/5Comment
have you got the part number for these shims i remember mine having a sticky pad on so you could stick it to the back of the brake pad so i might have to `butcher ` them to get them off!!!!!!!!
QUOTE=Big Lee M;576006]Anti squeal shims all the way buddy...... I got mine off eBay for £15 there we're advertised as boxster one but I got the par number and they turned out to be the right ones. They may be about £40-£50 from the dealers but it will stop the noise. Mine do it now and again with the build up of brake dust a quick wash and everything's fine again.[/QUOTE]ABY Cricket Green Pearl Coupe, blk leather
THE ONLY TROUBLE WITH DOING NOTHING IS KNOWING WHEN YOUR FINISHED!!!Comment
Subtle mods here and there
2011 A5 3.0 TDi - Lava Grey
With every option available
(except a towball)Comment
It's very strange you have to do this with the 996, with the GT3's I've never had any of the problems I had with the 996's on my old Coupe, they don't squeal and are rock solidget some of this stuff...its fantastic. http://www.camskill.co.uk/products.p...m20b918s2014p0
Upgrade to GT3s!
Jamo....it needs to see some usage first
With the ds2500's and previously using copper slip, i found they really gunked up.
I've cleaned and now lubed all the critical areas with ceratec and we'll see how they go. Plus...i'm OCD on the brakes i guess its fair to say :blush:sigpic
But the rs2 workshop book shows the spring clip ones,,
