Yet another 996 314mm upgrade
2 Zimmermann 100.1231.50 ordered from ebay - ~160 euro.
I'm a bit confused about the pads - Ferodo frp3051 should fit, but I'm thinking redstuff (road use only). Dealers sort by car, and I'm not sure exactly which Porsches the 996.351.425 was fitted on. Mostly it's a different pads for different years problem. I have tried a little reverse engineering from the frp3051, but I'm not totally convinced about the right redstuff pads. Anyone?Cheers, Torben
'94 B4 Avant S2Comment
All parts have arrived. I'm not sure about shortening the calliper pins - if it it necessary, and how to. I guess a file wont cut it?
Cheers, Torben
I used a angle grinder to remove material from the pinsComment
Project concluded - nice, simple, bolt on solution - thank's to Bambridge's precision work. The Blue Van is officially not unstoppable any more. This forum
I removed 1mm from each of the inside pins with the angle grinder, not much more to say - it's a walk in the park (when you have access to an vacuum bleeder).
Total pricetag - 1000 euro, including a lot of shipping. Not too bad, considering that only the calipers are used (and in very good condition), everything else is new.
Can I fit the G60's on the rear end?
Attached FilesCheers, Torben
