Standard RS2 brakes
  • audiman
    • 4827
    That white dust is the ally corroding away. I had the same problem on a customers RS2. You cant buy that metal peice, the calipers come complete. In the worst case, the brake pads stick in the caliper and can cause poor brake pedal feel, and also overheating of the pads/discs.
    The best place to purchase these calipers is VAGparts, £235+VAT
    Tom C - www.rcmr.co.uk
    Audi UR Quattro
    Audi 100 C3 2.0 5 cyl 115ps
    Audi B5 RS4 645ps 911nm
    • twoqu
      • Sep 2003
      • 3103
      #32
      Hi!,
      Not sure whether those plates are available from Audi, although they do appear to have a p/n: 8A0 698 430 & 8A0 698 430A. They are descriped as repair kit spring plate.
      They may be obtained from a Porsche dealer as this is common on all the brembo calipers using that construction. Remember seing an article on how to correct it by removing the original plates (difficult as lots of heat was needed on the bolts that retain them), cleaning the corrosion out, and replacing the new plates.
      Just need to know where Porsche sourced the calipers from. Not sure but I think it was the 968CS.
      Good luck.
      • audiman
        • 4827
        Dont know Robin, the screws are impossible to get out, they also corrode solid into the ally, you would need to split the caliper and drill them out!!
        Audi UR Quattro
        • robo
          • Aug 2004
          • 2086
          #34
          Originally posted by twoqu
          Hi!,
          Good luck.
          Porsche name is guide plates and audi repair kit spring plates.
          Get them from audi dealer as they are same money , it will save you allot of agro .
          _________
          Rob
          sigpic_________
          Rob
          • twoqu
            • Sep 2003
            • 3103
            #35
            Tom,
            Understood. Obviously if you can get the screws out then it is a cost effective solution. Depends upon how manky the calipers are in the first place I suppose.
            • audiman
              • 4827
              Someone had tried to remove these screws before me and had rounded the small allen key hole out !! I managed to move a couple of them using a hammer and chisel, but the others were in there for good.
              Audi UR Quattro
              • twoqu
                • Sep 2003
                • 3103
                #37
                Tom,
                I expect that would have been an Audi Specialist then!
                • audiman
                  • 4827
                  Funny you should mention that
                  Audi UR Quattro
                  • robo
                    • Aug 2004
                    • 2086
                    #39
                    I had to do this used hammer/chisel/drill combination my self , it worked for 1 month and then I got the brake squeal so I got my self 322 with 993tt brakes.
                    ______
                    Rob
                    sigpic_________
                    Rob
                    • RSBLURS2
                      • May 2004
                      • 25
                      #40
                      I'm doing the fronts tomorrow. Is there anything else likely to be lurking in wait? Do the front callipers suffer the same way and is ir eally OK to machine old discs?
                      • RSBLURS2
                        • May 2004
                        • 25
                        #41
                        Sorted. Took a while but they feel most excellent once again. I got my spare wheel out for the first time ever to provide the pressure to bleed the brakes and found it has never been out the packet so to speak! The Dunlop & wheel are brand new with a pretty chunky tread which looks a bit like Yokohamas. Tyres are next on my agenda as I noticed the wear indicators looming while doing the brakes so bang goes the money saved by doing the work myself!
                        • JPL
                          • Oct 2004
                          • 149
                          RSBLURS2, I've used GSF stuff for years and never had a problem with the quality of their kit, you could save a fortune going with standard kit. However, if you've got the cash for the big red upgrade then go for it. Give me shout if you need a hand, I've got full workshop facilities here (Strathaven) and it won't cost you a penny. Drive in/drive out, job done.
                          Cheers,
                          Graeme.
                          94 UrS4 Avant, slowly modding as we go. Now gone replaced with:
                          2001 S6 Avant, V8 works for me!
                          • JPL
                            • Oct 2004
                            • 149
                            Oops, came in half way through this thread, better late than never.
                            If anybody needs help/workshop in my area give me a shout, always happy to help.
                            Graeme.
                            • RSBLURS2
                              • May 2004
                              • 25
                              #44
                              Thanks. I'll probably upgrade next time the discs & pads need replaced, probably 20000 miles. Is the upgrade only on the front or is there a back upgrade as well? I think it sounds too much trouble with no guarantee of success to replace the guide plates and if I need new callipers are required bigger is better, especially as standard ones will still cost.
                              • afhgus
                                • Aug 2004
                                • 50
                                #45
                                Thanks for your post. I appreciate it. I've since found the plastic air guard inside the wheel is catching on full lock sometimes. I thought perhaps not enough air was getting to brakes causing overheating. My brake pads were new in Feb I think. Don't know what make but standard Audi/Porsche I imagine. Work done at QST. Cheers
                                Volcano black,134500 miles,standard,everyday transport, new rear discs, new door trims, replaced radiators x2, front/rear shocks(OE) + suspension bushes, recent alarm, undersealed, exhaust/head gasket, pulls like a train. big turbo whistle 315 hp
