Pulsing brakes
Where were you going with this comment? I thought as it doesn't pull in any direction when braking that it wasn't a caliper issue but more an hydraulic assist one
Sent from my HTC Desire using Tapatalk 21996 Audi S2 - 295bhp and 326lb/ft - Complete Rebuild Project
1994 Audi 80 - 2.0 8v (slow but reliable!)Comment
I think all the sensors are working ok now.
you can feel it at high speeds too, but just more obvious at lower speeds.
It feels like im coming on and off the brake pedal a bit, the front of the car is going up and down with the braking power1996 Audi S2 - 295bhp and 326lb/ft - Complete Rebuild Project
there's nothing at idle.
im starting to think that one of the pads is contaminated or the front discs arent within the correct tolerance of run out...might go pick a dti up tomorrow and measure them
interestingly..the rear right disc still has a band around the centre of the contact face that looks like it hasn't bedded in. i think they brakes are still coming in a bit1996 Audi S2 - 295bhp and 326lb/ft - Complete Rebuild Project
Will,
The sensor position is critical, on the ur there are white plastic caps that position the sensor at the correct distance away from the reluctor ring on the cv joint. Have you you checked each reluctor ring for debris or even a crack that can offset the distance?
MarkComment
Thats what I was told when I rebuilt my calipers , when I first drove mine after ages I had the same problem with the pedal feeling like it was pulsing all I done was re-bled the brakes then they felt much betterComment
ive rebled them 3 times now! was your whole car jerking as you braked?1996 Audi S2 - 295bhp and 326lb/ft - Complete Rebuild Project
thought i'd clear this up a bit!
Symptoms- under braking, the car brakes in a straight line but jerks with hard and soft braking
- has had a few abs errors with sensors but all currently working
Whats been done:- all brakes rebuilt - new seals etc
- 993 front brakes
- re-bled several times - no air present
- all pads are new
- rear discs are new
- front discs are skimmed (with in tolerance as far as i know, will check)
I've tried driving the car with ABS disabled and there was no change in the symptoms.
If a disc was warped or contaminated, would the car pull in the opposite direction to the stronger side?
I might do another 130mile round trip to measure everything up tomorrow. It's playing on my mind1996 Audi S2 - 295bhp and 326lb/ft - Complete Rebuild Project
If you're parked up and it doesnt pulse in neutral at idle, then 60mph in neutral at idle and they DO pulse its got to be discs or something.*Or is the speed of the pulsing consistent regardless of road speed?
Like Error said Id go for the dti gauge on each brake disc at a time, if the wheel's off at the time of checking then put the bolts back in tight with spacers of some sort, if and when you find the corner with runout take the disc off and check the hub right across the face of it and inside the hat of the disc.Comment
check the hub face too
