Big Brake upgrade??
i just allways thought when bigger calipers are fitted that there needs to be a corrosponding change in the master cylinder, force by area jazz. is the rs2 master cylinder differnt to the s2 one.1991 S2 3B Coupe, KW v1, solid sub frames, poly bushed, chipped, about 260 ish
Originally posted by stocious View Posti just allways thought when bigger calipers are fitted that there needs to be a corrosponding change in the master cylinder, force by area jazz. is the rs2 master cylinder differnt to the s2 one.
AFAIK the RS2 master cylinder is the same as the ABY S2 one.
John
i was under the impression that people just had to have eye candy.. glad thats cleared up.. thank you. seems logical now. maybe for christmass, big red might bring me some big reds1991 S2 3B Coupe, KW v1, solid sub frames, poly bushed, chipped, about 260 ish
I've ordered the mono blocks with pads both squeak bits and pins. spoke to kev re brackets and bolts. i think the part number for hard line is 893 611 707 is that right or do people just make new copper lines and use metric connectors. also does it matter what year a8 i get discs for or is it surely 323 x 30 with 5 bolt pattern?
You shouldn't need new hard lines? I didn't... just change the final flexi. Standard fittings are m10x1.0 on our cars
As for discs, search for a thread on 323 discs and how to order the right ones from camskill. It's a certain s8 disc you need, they did 2 sizes...
Sent from my GT-I9300 using Tapatalk 21996 Audi S2 - 295bhp and 326lb/ft - Complete Rebuild Project
http://www.s2forum.com/forum/showthread.php?t=50472
There you go!
cheers mate.i think I've found the flexi using part number. Im still confused with the discs how do you know your getting correct one. i want to order through ecp or gsf or another supplier i use. i am trying to do this on a budget as have spent silly amounts on this car since April. i get a trade discount through above companies so Will save money. want to limit cost of disc to 100 as its already over my budget. could do Will having a look at your brakes Will to get an idea of what to do.
I paid 90 from camskill and that's for grooved and coated! Doubt you'll find better/cheaper really....
If you take the code I ordered from that thread you'll get the right disc.
Originally posted by Jamo View PostThe big big setups eg RS6 do feel sharp but in doing so you lose the progressiveness of brake setup as its nothing nothing boom! brake lag
I have the GT3's and I feel they are the perfect comprimise between bite and progressive pedal travel.
Another thing is alot of comparisons are done with front brake upgrades only, doing both front and read has a massive effect and is definately worthwhile.
Regarding rear brakes upgrade, what s a bolt on setup upgrade for a S2 avant ??
i hear it s actually easyer to do one on a S2 avant than an RS2 due to the hanbrake, right ?S2 's and oldtimers
