Boxster S and RS2 brackets - does it work on Euro S2s?
    I bumped into this article which describes adding Boxster S front calipers to a NAmerican CQ wheel bearing carrier with S2 front hubs. Does it work on Euro S2s?
    AudiWorld was created to maintain the most comprehensive collection of Audi information anywhere in the world. Site includes Forum, Tech, Polls, Gallery, and more!
  • driftin jo
    • Sep 2007
    • 2222
    http://www.audiworld.com/tech/misc42.shtml
    That realy is a silly question given the amount
    Of people on here that have this set up, myself included.
    I'm very surprised you have not seen one of the
    Countless posts about this.
    • andy10v
      • 5996
      Yes, though normally custom brackets used due to cost, and direct fit with 314s, no machining required.
      3 stickies from the brake section
      Sold ABY-stock
        Originally posted by driftin jo
        That realy is a silly question given the amount of people on here that have this set up, myself included. I'm very surprised you have not seen one of the. Countless posts about this.
        Gee thanks jo, I hadn't been bitch-slapped yet today. I will try to be as nice to you in the future.
        I don't have an S2, there aren't any S2s in North America, so I never was concerned/interested in S2 brakes. I just wanted to share what I found. Sorry for the intrusion.
          Originally posted by andy10v
          Yes, though normally custom brackets used due to cost, and direct fit with 314s, no machining required. 3 stickies from the brake section
          Thanks for the informative, polite, answer Andy.
          • driftin jo
            • Sep 2007
            • 2222
            • driftin jo
              • Sep 2007
              • 2222
              No offence intended, i was genuinely
              Surprised you were not aware of this,
              Its not like your new here.
                No offence intended, i was genuinely surprised you were not aware of this, its not like your new here.
                And I was genuinely surprised to be bitch-slapped. Agree I am not a nooby but I know zero about S2 brake options because there is no need in NAmerica. Now C4 UrS brake options, that is another story:
                • Le S2 Audi
                  • Jul 2009
                  • 3805
                  New S2 - S8 & RS2 -RS6 Keyrings
                  • mcandmar
                    • Apr 2004
                    • 5118
                    You cant blame anyone for being confused on brake options, its a minefield. Key points are Boxster S calipers are the same calipers as a 996 911. And the hub fitment for the caliper is the same for CQ20v and S2, and yes you can use RS2 brackets with spacers to move the caliper out from the hub for 323mm disks. ~2mm springs to mind. Then there are the Seat brackets some people used, and bambridge brackets if you just want it to work first time. If its a CQ you have the head ache of finding disks the right size with a four stud bolt pattern, or take the easy way out and convert to S2 5 studs hubs and use A8 disks.
                    91CQ20v - Gone to a new home
                    93UR-S4 - The Magic Carpet
                    94S2Bus - The Emerald Express
                      Originally posted by Le S2 Audi
                      And beer?
                        Thanks for the reply. By spacers, do you mean the use of washers, say two flat washers, 1 mm thick, kind of thing?
                          Washers are a bit ghetto for my taste. I would use a piece of plate drilled for the caliper mounting holes and milled to the right thickness, which would be 0.5x the difference in disc diameter
                          • mcandmar
                            • Apr 2004
                            • 5118
                            As above, i had a piece of steel plate cut to size. I wouldn't use washers, not enough surface area in contact.
                            • Jonas_R
                              • 3780
                              • Country: Denmark
                              If you use big diameter washer I dont see the problem. The mating surface on the RS2 caliper bracket is not that big.
                              Sleeper S2 Avant +450
                              A6 Avant 2.7t Stage 3
                              Audi S2 Coupe RS2'ed
