Porsche Cayenne caliper in Audi S2 obstruct
  • [sTeeWie]
    • Jul 2011
    • 106
    To judge by the pictures, I can obstruct the brake in such a way that the big piston sits below and is called first by the brake disc.
    And without that one can badly measure the brake and also without that noises exist?
    • [sTeeWie]
      • Jul 2011
      • 106
      Originally posted by fluk3
      I would like to install the brake in the next few days.
      Can I the brake caliper install now so, that below the large piston first detected from the brake disc?
      I have full braking power?
      Can I dispense the brake well?
      To run off the pads evenly?
      Noises when the brakes on?
      • [sTeeWie]
        • Jul 2011
        • 106
        Nobody can help me?
        There have so many installed the caliper so that the small brake piston reaches first.
        Are there problems with irregular past pads or less braking power?
        • marson
          • Feb 2011
          • 80
          Try to fit them like original like porsche . I would ......
          • [sTeeWie]
            • Jul 2011
            • 106
            I like not visually if the above cast nose is visible.
            Therefore, I would spoil the caliper so that the large piston is first started.
            Are there problems with it?
            Have now seen both versions.
            • quattro84
              • Mar 2006
              • 947
              Please post in German because this translated stuff is impossible to understand.
              Bitte, leider auf Deutsch...
              Ich würde das montieren wie Porsche das gemacht hatte, ZL auf links, und ZR auf rechts... und das bedeutet der kleiner bremszylinder unter richtig?
              Gibt es schön preize für die adaptors?
              • [sTeeWie]
                • Jul 2011
                • 106
                I already have a price for the adapter. He is 230 €
                As written, I do not like visually.
                Can not I have them mill off your nose?
                I did it once circled in red
                  #23
                  In relation to the query on which piston is at the top?, I would suggest it will automatically be correct once the bleed nipple is kept at the top of the caliper when it is mounted, as obviously it needs to be in this position to allow any air to bleed out.
                  HTH.
                  To all, I presume the 360mm disc and matching caliper means the Audi Q7 "18z", not sure of the correct designation, is the appropriate caliper for the 360 mm disc.
                  If that is the case what range of disc sizes can be used with the 18z caliper ?
                  and
                  If that is the case what range of disc sizes can be used with the 17z caliper ?
                  Lastly,where does one buy the appropriate caliper mounting brackets and bolts for either the 17z or 18z calipers ?
                  Thanks.
                  • martinjs
                    • 3205
                    Only if they are being used on a car with leading calipers as per the cayenne.
                    So are ok for a UrS car.
                    Whereas as S2 has trailing calipers so the bleed nipples and cross over tube need to be swapped.
                    • [sTeeWie]
                      • Jul 2011
                      • 106
                      Ich werde das ganze so verbauen, wie es viele andere auch verbaut haben.
                      Werde dann berichten, wie sich die Bremse verhält.
                      Die ZR18/ZL18 Bremssättel sind mit Bremsscheiben der Größe 335 bis 360mm und einer Dicke von 32 bis 34mm fahrbar.
                      Die ZR17/ZL17 Bremssättel sind mit Bremsscheiben der Größe 325 bis 340mm und einer Dicke von 30 bis 32mm fahrbar.
                      Die Bremssättel wurden bei Touareg, Q7 und Cayenne verbaut.
                      Passende Adapter für ZR18/ZL18 Bremssättel in Verbindung mit Bremsscheiben vom S8 in 360x34mm kann ich dir für 230€ anbieten.
                      Jedoch nur passend für Audi S2.
                        #26
                        Thanks for reply.
                        Anyone any ideas on caliper brackets ?
                        • Mischa
                          • Sep 2008
                          • 33
                          • Country: Australia
                          #27
                          Thanks for reply.
                          have them made up custom
                          Daily: '08 Golf GT TDI
                          Toy: '95 S2 Coupe
                            #28
                            Thanks, but outside my level of ability / time / patience.
                            That's why I was checking.
                            • sam80quattro
                              • Oct 2006
                              • 1496
                              I made this set last year and ran with it all summer 2011 it worked perfectly :-)
                              Spec
                              Caliper porsche turbo
                              Disc audi a8 360x34
                              Adaptors spec made :-)
                              Rims 18" ultraleggera
                              are the adaptors for sale anywhere or 1 offs?
                              thanks
                              • Masterblaster
                                • Feb 2009
                                • 300
                                Ultimot.de sells them..i will use them as well...
                                UrS4 with Comp CT4367,Vems and other goodies!!!! SOLD!
                                New project Audi S3 with GTX 28/67...
                                http://www.s2forum.com/forum/showthread.php?t=40308
