Porsche Cayenne caliper in Audi S2 obstruct
  • Rocco
    • Aug 2007
    • 6393
    • Country: Spain
    #31
    Originally posted by Masterblaster
    Ultimot.de sells them..i will use them as well...
    adapters for cayenne turbo calipers with what discs to S2 hubs?
    • sam80quattro
      • Oct 2006
      • 1496
      audi a8 360x34
      can be bought from carparts4less.co.uk for £75 per disc iirc
      • Rocco
        • Aug 2007
        • 6393
        • Country: Spain
        #33
        Originally posted by sam80quattro
        audi a8 360x34
        is that serious?
        • sam80quattro
          • Oct 2006
          • 1496
          Pagid Brake Disc (Front) Part Nos.: 104441558£75.60Audi A8 6.0 (2008) £75.60
          • sam80quattro
            • Oct 2006
            • 1496
            GRAND TOTAL (inc VAT): £136.20 that's for the pair, using a £15 off voucher code thats on the homepage..
            • Rocco
              • Aug 2007
              • 6393
              • Country: Spain
              #36
              Are them floating rotors with lightweight bells?
              • sam80quattro
                • Oct 2006
                • 1496
                yes includes fitting too
                • Rocco
                  • Aug 2007
                  • 6393
                  • Country: Spain
                  #38
                  the A8 rotors has to be heavy then
                  • sam80quattro
                    • Oct 2006
                    • 1496
                    13.53kg ... so yes lol
                      #40
                      If one wanted to go mad and was concerned over the weight of 360mm x 34mm one piece discs, however inexpensive, where would one get that size disc with an alloy bell so that the weight is more reasonable, even if the price is not ?
                      Thanks.
                      • SteveH
                        • 4460
                        You can use the 350mm S5 disk. Similar weight I should think unless you go two piece. I'm looking at getting prices for the carrier to be made up, just need to get my lad to create the .stl files.
                        91 Modded 3B
                        14 A6 Avant Black Edition
                        • vr6peter
                          • Dec 2003
                          • 223
                          • Country: Austria
                          #42
                          I have 365mm RS6 discs twist off to 351mm.
                          Fits under 18" BBS LM 127 with self made adapters
                          Peter
                          • Rocco
                            • Aug 2007
                            • 6393
                            • Country: Spain
                            #43
                            Peter
                            Do you know the Rs6 rotor weight?
                            Just for comparison
                            • vr6peter
                              • Dec 2003
                              • 223
                              • Country: Austria
                              #44
                              12,3 kg I think.
                              • A1QSHIP
                                • Aug 2004
                                • 975
                                From the picture above it appears that the brake pad does not cover the rotor completely.
                                "Nulla tenaci invia est via"
