aftermarket handbrake calipers
  • Pembo
    • Aug 2004
    • 295
    Here is the link.
    Happy to provide photos via email as I can't upload any to this forum. Administrators please help me do this!
    Pembo
    quattro - Original 4WD rallying
    Rally Car photos
    • recall
      • Jun 2010
      • 336
      Brilliant.
      my email is recallzzz2@hotmail.com.
      Thank you very much.
      Boost is what makes the world go round.......!
      • simon20vq
        • Dec 2010
        • 1379
        Lance maybe of interest but I'm in the process of doing something similar. I've come up with a cheap option (bit heavier than I would have liked) using Jaguar rear calipers. They have the same set up for the handbrake cable, Jag disc is 20mm(?) so 22mm(?) x 300mm s4 disc not a problem. Just need to make a bracket to mount out of steel plate.
        • Pembo
          • Aug 2004
          • 295
          Pembo
          Rally Car photos
          • John B
            • Apr 2008
            • 926
            Just be careful with small mechanical calipers like these. They tend to be made for kit cars (of low weight compared to our heavy S2s) or for motorsports applications where road legality is not required. Calipers have to be capable of a certain loading per MoT in the UK. I did loads of research into the subject and came up with conclusion.....why try and re-invent the wheel when a solution exists like the R8 / Lambo / Aston which is approved and will easily hold the weight of our cars I've nearly finished the write -up of my conversion for the coupe, so watch this space folks
            2001 996 C4 - Being renovated
            • Sleeper_Avant
              • 2372
              plenty of old jag XK/JR`s and ferraris with very cheap calipers being broken at the minute lads
              1993 URS4 Avant Emerald Green 350+bhp
              1991 Ford Sierra Sapphire 4x4 in Magenta
              BoooOOOSSSSSTTTT BANG BANG CHIRP CHIRP
              • Thuppu
                • 4115
                Handbrake option with big rear calipers. Could give some ideas of some diy mechanism for brembo calipers..?
                • A80Avant
                  • Sep 2005
                  • 10873
                  • Country: Greece
                  #23
                  Where has this come from? Any more details?
                  • Thuppu
                    • 4115
                    Here is some info: http://www.miataturbo.net/suspension...s-68828/page2/
                    • Thuppu
                      • 4115
                      Have been thinking about this mechanical handbrake thing. Seems that all alternatives are quite expencive. I got a pair of 4-pot brembo calipers for 150e and I don't wan't to spend more(like 200-600 euros) on mechanical calipers. And usually the mechanism moves in wrong direction to be used with UrS4 stock brake cables. So I will try to fabricate small and simpple calipers. I did already buy brake pads to use with them. They was cheap(10euros/4pcs) and are used in many different older cars, like Alfa, Audi, Opel, Porsche, Saab, Volvo, etc... so they are quite easy to get.
                      • Rusty
                        • 18953
                        Design your own? Could integrate them with the caliper carrier.
                        • Thuppu
                          • 4115
                          We shall see how it turns out... First proto designs soon ready for cutting. The idea is to make a carrier that holds both the 4-pot Brembo and this mechanical caliper.
                          • Henkjan
                            • 1705
                            Originally posted by Thuppu
                            Have been thinking about this mechanical handbrake thing. Seems that all alternatives are quite expencive. I got a pair of 4-pot brembo calipers for 150e and I don't wan't to spend more(like 200-600 euros) on mechanical calipers.....
                            I have the same thoughts.. I have a set of Boxter calipers for the rear, but the handbrake thing had me waiting..
                            • Rusty
                              • 18953
                              Are there any standard style calipers that can accomodate the disc thickness you require? If you could get some off a shopping car, which were alloy, then just seal up the hydraulic part and you're laughing. £50 off ebay for a common car... Could even shave down the pad thickness, if it helped.
                              • Thuppu
                                • 4115
                                The UrS stock rear pistons could be used, but I don't like the thing that the handbrake is always stuck on these. And also the hydraulic part buggs me.
