I wasn't going to make them for sale. But if there is enough interest for a group order, I could maybe make a batch. But they need quite much of work to be done. If fitted in S2 they may need a different system for the cables and also the fitting carrier may need to be different..?
Keep also in mind that these are not very strong and powerfull calipers, you can't lock the tyres, but they where enough to clear mot and hold the car steady. As the layout is open, the floating pinns don't have seals, they would need maintance and new lube quite often. There is no automatic adjustment for the disc- and pad wear, that needs to be done with shimms.
