Rear brakes upgrade
  • Pirvu Eugen
    • Apr 2007
    • 1978
    • Country: Romania
    Rear brakes upgrade
    I searched the forum for this and i couldint find the answer.
    Somebody....successfully installed the urs4 rear brakes to S2 coupe?
    I had this into my car...but with some merc discs and some spacers between the hub and disc. Not the best...
    I bought the s4 300mm discs....but the minimum diameter for the pads to stay on the entire surface is 280mm. This is good for the S8 caliper brackets..but not for the urs4 ones.
    For the urs4 you need an 270mm disc.
    You know an 270mm disc wich can fit these brakes?
    Thank You!
  • Rusty
    • 18953
    On the coupe, I thought the discs were machined down to 280mm? s2central.net did this originally, I think Pete Reeve sold a kit with all the bits in too.
    • Pirvu Eugen
      • Apr 2007
      • 1978
      • Country: Romania
      Thank you Rusty... I measured..and...with urs4 caliper brackets....the 280mm dosint fit. The urs4 brackets on s2 coupe is possible with 270mm only.
      • 90quattrocoupe
        • Nov 2003
        • 771
        You need to use S8 rear caliper carriers along with the UrS4/6 rear calipers. Then you can use the 280mm disc.
        Greg W.
        • Pirvu Eugen
          • Apr 2007
          • 1978
          • Country: Romania
          Thank you Greg! This i know...but i have an complete set from an urs4 and i wondered iff there are some discs to fit these. Is about the hat height. The s8 carriers are expensive, aprox 140 euro each. The only disc may fit is the beetle or A3 one. 1j0615301m. But needs center rebore and holes enlarged.
          • Colesy
            • Feb 2009
            • 2980
            Pete @ Quattro Corner used to have stock of new S8 carriers, they were much less than 140 euros each, could be worth asking.
            • Pirvu Eugen
              • Apr 2007
              • 1978
              • Country: Romania
              This is indeed a nice option...but...as i allready have these...i was thinking at an upgrade for the coupe using these as a lot.
              I found an disc. Is an Merc A class. 168 421 06 12. This needs just 0.5mm center overbore and some washers between caliper brackets and hub.
              I think this will be a nice solution for somebody with these calipers and brackets.
              What you think?
              Regards!
              Eugen
              • Pirvu Eugen
                • Apr 2007
                • 1978
                • Country: Romania
                I measured again...and these discs will work on coupe with urs4 rear brakes with aprox 2mm distance washers between brackets and hub.
                • andy10v
                  • 5996
                  I have this setup fitted and working
                  B7 Disc, 300x22 vented - 8E0 615 601R (turned down to 280mm)
                  A8/S8 carrier - 4D0 615 425C
                  Calipers from RR quattro or UrS4/S6 - 447 615 423 and 447 615 424
                  S8 pads for those 280mm discs - 1J0 698 451L
                  50mm long caliper carrier bolts - N101 815 02 Shortened to ~35mm for the task
                  Also recommended along the way is new brake lines and clips for handbrake...
                  S2 Coupe rear hose - 893 611 775
                  Brake union clip clamps - 4D0 611 715B
                  Handbrake cable lock clip - N900 527 02
                  Sold ABY-stock
                  • John B
                    • Apr 2008
                    • 926
                    Go for bigger brakes! You only live once
                    http://www.s2forum.com/forum/showthread.php?t=62766
                    2001 996 C4 - Being renovated
                    • Pirvu Eugen
                      • Apr 2007
                      • 1978
                      • Country: Romania
                      Lol!...Yes! Thank you guys! I will check the price for those S8 brackets.
                      All the best!
