I searched the forum for this and i couldint find the answer.
Somebody....successfully installed the urs4 rear brakes to S2 coupe?
I had this into my car...but with some merc discs and some spacers between the hub and disc. Not the best...
I bought the s4 300mm discs....but the minimum diameter for the pads to stay on the entire surface is 280mm. This is good for the S8 caliper brackets..but not for the urs4 ones.
For the urs4 you need an 270mm disc.
You know an 270mm disc wich can fit these brakes?
Thank You!
Thank You!
