I've been getting this annoying sound that comes on when I have been driving for 10-15 minutes. It's squeaking and it disappears when I put my foot very light on the brake (not as much as I can notice any braking on the car). When pressing the pedal it first get's more loud and then it disappears but all this is before there is any kind of brake force felt on the car. I think it is coming from the front left hand side but as with all sounds it's hard to locate them when driving.
What I have done this far is using a small grinder I went over inner/outer edges on both sides of the brake discs to be 100% sure there was no big edge there making the sound. I did also loosen the caliper but due to a brake hose being stuck I couldn't take the caliper up on the bench to check it.
Also took some pictures to illustrate some. The discs are measuring 304mm from what I can measure when they are on the car.
This is the brake hose that is stuck. Any good tip on howto get it off? I've been spraying it with rust-remover spray now for three days a couple of times a day and tried heating it and giving it shocks on the side. Already ruined one of the sides of it trying to get it off :X
Here is a shot of the caliper from the back. Where the ring is marked It seems like the gasket is broken one the piston. Since this brake hose is stopping me from being able to open up and look closer at it I'm just guessing tho.
From this scheme I can spot two rep-sets for the pistons. One for 44mm and one for 36mm (13 and 14). Is the only way to find out what I got to measure on the car or is it like in the drawing that the upper is 44m and the lower is 36mm? It did sound weird to me that they would use two size of pistons.. Is there other parts in this picture that could be related to my problem?
Since I think I have to ruin the brake hose to get this thing off I didn't do much more work on it since I will have to order other parts first. Since I lack experience with these calipers from Brembo what is usually the problem with them? I'm suspecting that the sound is coming from the brake pad not moving flat onto the brake disc due to a broken gasket that again has made one of the piston's not returning as much as the others. I did try to feel for wheel bearing issues but it did feel tight.
Feel free to let me know if my theory sounds stupid and way off
