Porsche 996 & 323x30 disc question
  • Rusty
    • 18953
    @ S2Ant
    As they're 4 pots and made by Brembo I thought that too. If Cupra R calliper carriers work on the S2's with Porsche callipers then I'd assume that the callipers (in a reverse psychology kind of way) work too, maybe not to the same level, but better than the standard stuff... which is scary at times!
    • 90quattrocoupe
      • Nov 2003
      • 771
      Originally posted by Andy_Casey
      Will Brembo callipers fit or do they have to be specific Porsche? There's a few sets on Ebay with a full setup off a Seat Leon, some Mitsubishi evo 6... Might be cheaper than something with the 'P' word on!
      Andy,
      You would need to know the brembo part number for Porsche caliper.
        #33
        Greg,
        Did you find the Porsche or Brembo P/N for the 996 calipers ?
        Sorry to chase you - I'm just trying to close this one in my head.
        If we can X-ref the Porsche numbers to Brembo numbers then it should be easy to check if the Seat application is the same...
        Paul
        • S2 Ant
          • 3682
          i have a pair of the big reds on the floor of my bedroom, says porsche on one side and brembo on the other, however cant see any part numbers on them anywhere
          Ant
          2011 Kawasaki Z1000
          • 90quattrocoupe
            • Nov 2003
            • 771
            Originally posted by S2central.net
            Greg,
            Paul
            Paul,
            Sorry, still at work. Got to remember, LA is some 10 hours behind you guys. You are at home and I am still at work. Will get the number for you in about 2 hours. Hey, what you guys need is a Porsche Family Album.
              #36
              Actually LA is only 8 hours behind the UK, but yes I kinda conveniently forgot your were stateside... D'Oh
              Paul
              • 90quattrocoupe
                • Nov 2003
                • 771
                Greg,
                Paul
                Paul,
                Just got home from work. Porsche part number for 996/BoxsterS calipers.
                This is for 2000 as this is the latest Porsche family album I have.
                996(black)
                996 351 425 22 left
                996 351 426 22 right
                BoxsterS(Red)
                996 351 425 11 left
                996 351 426 11 right
                The last two digits represent the color of the caliper.
                Brembo sites do not list any number for Porsche calipers. So I don't know how to cross reference the Seat R caliper to the Porsche caliper.
                Earlier Spanish and David where posing the question, why if the Porsche rotors for the 996 and BoxsterS are 322X32, do the pins on these calipers have to be filed to fit a 30mm wide rotor.
                Well the Porsche Family Album does not give rotor sizes like the Audi FA. So I went searching. Brembo has nothing in there catalogues that cover the newer Porsches. Must be Dealer exclusive.
                So I went to the site for Ate. This is where I found out that the 323 and the 314 A8 rotors had the same dimensions, as far as offsets and hats go.
                Alas, the rotors on the 996 and BoxsterS are only 318X28, not the 322X32 as mention earlier and in other posts. Now we know why the pins on the calipers need to be filed.
                Ate site.
                Just look up Porsche BoxsterS front brakes.
                • martinjs
                  • 3205
                  Agreed, i filed my pins down 1mm each side to give just over 1mm clearence from disk.
                  • s2driveruk
                    • 12696
                    brembo part numbers usually start with something like 207.xxx.xxx then the porsche or manufacturer p/n is beneath it, so the porsche ones have the model/colour/caliper ref, e.g. 996.351.422
                    1992 3b S2 Coupe
                      #40
                      Originally posted by 90quattrocoupe
                      Paul,
                      Cheers Greg - mighty useful info there. Thanks again !
                      Paul
                      • Rusty
                        • 18953
                        I'll ask some of the ebayers what part numbers are written on their callipers and see what turns up! IIRC people have used Cupra R calliper carriers on the S2 with Porsche callipers??
                        • The Spanish
                          • Nov 2003
                          • 719
                          #42
                          Ate site.
                          You are completely right.
                          Thought they used the same discs size as 993 turbo/ C4S 323x32mm
                          Do you know the size for the 997 and/or 997 S front rotors?
                          Rafael
                          94' RS2 Coupe TT (Twin Torsen )
                          • AndyP
                            • 6049
                            I've just phoned my local Seat dealer and for the caliper mounting brackets for a Cupra R with Brembo calipers they want.....£124 EACH
                            I think that should put that subject to bed!!
                            Andy
                            • S2 Ant
                              • 3682
                              Thats a sharp rise of about £100 on what has been posted previously.
                              Ant
                              2011 Kawasaki Z1000
                              • Rusty
                                • 18953
                                well that's put a dampener on my BBQ!
