Porsche 996 & 323x30 disc question
  • s2driveruk
    • 12696
    Correct me if i am wrong but the boxster S calipers i thought bolted striaght up without any modification - am i right in thinking that that link suggests the pad rests have to be filed down 1 mm then, i thought this was only the case on the NON boxster S caliper?
    David
    1992 3b S2 Coupe
    • The Spanish
      • Nov 2003
      • 719
      I have one question.
      Those calipers are design to work with 323x32mm rotors (Boxters and 996 front rotors)
      Why if you are using a 323x30 mm rotor, 2mm thinner than the Porsche one, do you need to take 2mm of the pins (1mm per side)?
      94' RS2 Coupe TT (Twin Torsen )
      • s2driveruk
        • 12696
        that was my point I thought that was the case on the standard 986/boxster caliper to squeeze a 30mm thick disc into a space normally reserved for a 28mm. The boxster S caliper normally takes a 32mm wide disc so no work needs to be done, simple bolt up with the appropriate bracketry.
        1992 3b S2 Coupe
        • S2 Ant
          • 3682
          They also are 332mm not 323mm on Porsche cars.
          Ant
          2011 Kawasaki Z1000
          • The Spanish
            • Nov 2003
            • 719
            #20
            I am almost sure they are 323mm
            Turbo and GT3 are 330mm
            • jeroen
              • Aug 2004
              • 100
              #21
              so how much would the boxter S calipers-rs2 brackets-brakepads-S8/A8 323mmdisks-and brake lines set you back??
              • S2 Ant
                • 3682
                Calipers seem to be going for around £300-350 a pair used, brackets i believe are around £80 a pair, textar pads around £40 and discs i think are around £40 each.
                Could be wrong, thats just from memory
                Ant
                2011 Kawasaki Z1000
                • jeroen
                  • Aug 2004
                  • 100
                  #23
                  so its not that expensive than? say 600 punds to have everything.
                  • jeroen
                    • Aug 2004
                    • 100
                    #24
                    and do you get the used calipers from ebay always???
                    since i've been reading some disturbing stuff about the reliability, and i have never bought anything on the net.
                    • S2 Ant
                      • 3682
                      they often come up on eBay.
                      They are also available from a porsche dismantlers in LA, in the states at a good price however shipping costs are quite high.
                      I was quoted $400 a pair + shipping (USED)
                      Failing that of course, VAGPARTS sell them brand new i believe.
                      Ant
                      2011 Kawasaki Z1000
                      • 90quattrocoupe
                        • Nov 2003
                        • 771
                        Originally posted by S2central.net
                        Greg - I liked that write up - it is one of the better ones I've seen, and with your permission I would like to include it on S2 Central. Firstly as a link to the fourtitude site, and then as part of my site. OK ? You will be credited of course for services to the sanity of S2 owners around the world.
                        Two more Q's
                        Were any spacers and such required or did the 996 calipers mount straight onto the RS2 caliper carriers ?
                        Out of interest - What is the Porsche or Brembo part for the 996 calipers ?
                        Paul
                        Paul,
                        You are more than welcome to use the information. In fact, later when you make the material part of you site, I hope you will host the pictures. I tried to get Fourtitude to host the pic, but alas they won't do that. If people change ISPs the pictures are lost. Then you start all over again. Don't need credit as long as it helps answer a few questions. I got most of the information from this forum anyway. I just took pictures while doing the fit up, and put it together.
                        No spacers are required for using the 996(black)/BoxsterS(red) calipers. Using the RS2 carriers, everything was a bolt up.
                        I will have to get back to you on the part number. I am at work and the Porsche family album is at home.
                        David
                        David/Spanish,
                        You are not wrong. The problem is this. Even thought the caliper, carrier, and the A8 rotor are all bolt ups and fit well, the caliper is not centered on the rotor. If I remember correctly, the caliper sits slightly outboard of the center line of the rotor, or closer to the inboard pins. These actually are the ones that should be filed.
                        I will use an anology to give the reason why I suggested filing off all the pins. The UrS guys who use the same brakes, are always discussing what is the proper way to mount the calipers, with the smaller pistion coming before the larger piston or visversa. They are always debating this. Fortunately, these calipers bolt on the same way on our coupes as they do on the Porsches. The UrS group has to flip the pistons and the cross tube.
                        By the way, small piston comes first. But, this discussion is always coming up on the UrS forum and sites.
                        Well, if I mentioned only filing down only one pair of pad pins, it would always be discussed about whether it was the inboard or outboard set of pins. So I said, file down all four. What I did, was measure all the pins for height. Subtracted 1 mm from the longest pin, filed down the longest pin 1 mm, and then matched the other pins to it.
                        As brought up above, I bought the Calipers from LA Porsche Dismantlers. I got a deal on the rotors, and the carriers were new. I made the RS2 hardlines from a VW 400mm hardline, and bent it to fit. The Calipers were $200 each, (for the black, reds[BoxsterS] would have been $300ea), the carriers were $275 from Europrice, the rotors were $200(deal), and the brake lines were $6 each. Bolts and other hardware say $20.
                        So the total for me was, $907. I think that was a savings of about $400 off the cheapest aftermarket brake kit I could find. That 400 allowed me to buy the 5X112 hubs I needed to do this upgrade.
                        Hope this helps.
                        • s2driveruk
                          • 12696
                          Top info Greg!!!!!! thanks
                          1992 3b S2 Coupe
                          • Rusty
                            • 18953
                            Will Brembo callipers fit or do they have to be specific Porsche? There's a few sets on Ebay with a full setup off a Seat Leon, some Mitsubishi evo 6... Might be cheaper than something with the 'P' word on!
                            • Rusty
                              • 18953
                              More specifically this setup...
                              http://cgi.ebay.co.uk/ws/eBayISAPI.d...e=STRK:MEWA:IT
                              • S2 Ant
                                • 3682
                                From what ive read in all honesty i think those calipers prob would be of use with perhaps minor modifications, altho dnt quote me on that
                                Ant
                                2011 Kawasaki Z1000
