RS2 brake pad change advice
  • Braeckie
    • Jan 2010
    • 22
    • Country: Belgium
    Originally posted by Rikki Kitto
    Sure mine had the individual type plates in them when I last changed the pads
    Great! I'll test the Porsche individual plates then.
    • Rikki Kitto
      • Feb 2010
      • 6276
      I think they might actually be better than the connected plates as it allows for slight variations in movement between the pistons, just a thought
      • diesel des
        • 3896
        How did you get on with the Porsche damper plate's
        Sent from my Moto G (5) using Tapatalk
        • Rikki Kitto
          • Feb 2010
          • 6276
          Is it a problem not fitting or using these plates
            I don’t use them
            • treebirch
              • May 2014
              • 244
              #21
              I would be careful pushing the pistons back into the caliper casting without cracking off the bleed nipples, it's relatively unlikely, but pushing fluid back through the system could cause some damage to the ABS pump especially if it is contaminated. It's good practice to give the brakes a bleed anyway when you're changing the pads. I made up a really nice little bleeding device the day, it's much easier if you can get someone to operate the pedal for you than try to do it on your own! Also, as above, I don't bother with the dampers.
              NB, the photo is not of the brakes on my RS2! Its my wife's A6.
              • diesel des
                • 3896
                #22
                I also don't use them but find that anything better than viewing stock ish pads make noise. The rs14 pagid pads I ran to the ring and back on and they were extremely noisy. Work well though... Was thinking that the dampers might shut them up enough to daily them.
                • Rikki Kitto
                  • Feb 2010
                  • 6276
                  When you say noisy what sort of noise, as long as they ain't screeching or squealing I don't mind
                  • diesel des
                    • 3896
                    #24
                    The noise was very loud. It was squeeling like a pig. I don't mind some noise but this was way too loud. Mostly the pads fault, as they aren't a road pad, but I like how they work so am looking to find something to quiet them down from mental to just noisey.
                    • Rikki Kitto
                      • Feb 2010
                      • 6276
                      Mines like this at the minute but am fitting Brembo pads when the new callipers go in so hopefully no more screeching as it makes it a right pain to use the brakes
                      • Braeckie
                        • Jan 2010
                        • 22
                        • Country: Belgium
                        #26
                        Ok, I bought the Porsche dampning plates from the local Porsche dealer. Price was about 8-9 euro per dampning plate.
                        For once, the Porsche solution is cheaper than Audi!
                        The Porsche plates fit totally easy into the calipers. During test ride, no more squealing brakes. Excellent!
                        Porsche numbers are:
                        44mm plate:
                        96535109600
                        36mm plate:
                        96435109601
                        • Rikki Kitto
                          • Feb 2010
                          • 6276
                          So just fitted the new calipers and pads without the anti rattle shims, everything is working fine
                          This gallery has 2 photos.
