Can the brake bomb cope
  • mac2226
    • Jun 2008
    • 1289
    Hi sounds a bit dumb but can my brake bomb cope with extra braking I now have as I've got porsche cayenne 6 pots up front and 4 pots boxster at rear both running 330mm discs.Any body who have similar setup to mine?
    It's the master cylinder you need to think about - probably ideally you'd fit a larger one. Calculate the piston area Vs stock. You'll probably find you have longer pedal travel but it should cope OK if its well adjusted
    • mac2226
      • Jun 2008
      • 1289
      Thanks error will do
      • s2driveruk
        • 12696
        is there an obvious upgrade from the parts bin to consider if you wanted to install a larger master cylinder?
        1992 3b S2 Coupe
        • ManiacuV6
          • Dec 2009
          • 458
          • Country: Romania
          I remember that Cayenne has a 27mm diameter piston in the master cylinder. Hence you have 2 options: using a bigger master cylinder or get used with the long travel of brake pedal. Is not quite a big difference.
          Audi S4 2.2T 5 spd 1992 for parts
          AUDI A4 1.9TDI daily use
          Audi 80 Quattro 2.0 16V (ACE) aka Competition
          • mac2226
            • Jun 2008
            • 1289
            Thanks maniacuv6 will have to take it for drive and see if I can get use to pedal feel if not will change master cylinder
            • europeanme
              • Oct 2005
              • 3817
              if its any help the slightly longer pedal travel is fine once you get over the "nothing, nothing, kiss windscreen!".....
