Hi sounds a bit dumb but can my brake bomb cope with extra braking I now have as I've got porsche cayenne 6 pots up front and 4 pots boxster at rear both running 330mm discs.Any body who have similar setup to mine?
Can the brake bomb cope
It's the master cylinder you need to think about - probably ideally you'd fit a larger one. Calculate the piston area Vs stock. You'll probably find you have longer pedal travel but it should cope OK if its well adjustedPanthero Coupé quattro 20vt
I remember that Cayenne has a 27mm diameter piston in the master cylinder. Hence you have 2 options: using a bigger master cylinder or get used with the long travel of brake pedal. Is not quite a big difference.Audi S4 2.2T 5 spd 1992 for parts
AUDI A4 1.9TDI daily use
Audi 80 Quattro 2.0 16V (ACE) aka Competition
