After startup, I normally have a very hard brake pedal when driving a few metres then it goes ok after about 1 minute. Occasionally during driving I get that same feeling, very hard brake pedal and almost no assistance when braking, what could the problem be in this case? Perhaps I need to re-bleed the brakes?
Think the accumulator is working fine as after startup then the pressure builds fine. Also I do have two rear daff ABS sensors (I think two at least!) would that have anything to do with it? Cheers
