Sfera è la divisione Server & Hosting premium del gruppo Register.it, parte di team.blue , realtà europea leader nei prodotti digitali per il business. Orig
they are something stupid weight wise. I remember borrowing some from a local dealer to check fitment on a set of brembo monos from a Megane before going down the 996 c2 route.
at 100mm offset from centre, and keeping the top of the disc in the same location, the caliper would have to move up by the following amounts over and above the diameter difference.
As the 330 is the largest disc that the caliper is designed to accommodate (albeit in 28mm thickness), you'd have to accept a 1.8mm overlap or decrease some clearance from somewhere. I'd suggest that you could get it down to a 1mm clearance with a bit of a close shave!
