Relief valve is part of it, and the servo is underneath, its the pipe on the bottom.
Brake Bomb replaced still warning signal
Tom C - www.rcmr.co.uk
Audi UR Quattro
Audi 100 C3 2.0 5 cyl 115ps
Audi B5 RS4 645ps 911nm -
New ones aint cheap. 280+vat retail and the servo is around 600 quid!!!!!!!!!
I havent found anywhere that can recon them yet, but i know of a citroen place that does the suspension spheres for them, they might be able to recon an Audi item as its the same idea.Attached Filessigpic
Audi UR Quattro
Audi B5 RS4 645ps 911nmComment
Yeah i think so mate, the pipe 12 is the high pressure feed.sigpic
Audi UR Quattro
What the whole light!! LOLsigpic
Audi UR Quattro
I've tried to do the hydraulic test from the write up. The return from the servo is the pipe on top as far as I can work out. Anyone got a clever way of undoing this pipe? The nut is right against the bulkhead and you cannot get a proper brake pipe spanner around it. I think I'm going to round the nut with a normal spanner...doh
Any other ways of testing that the servo seals are good and the bomb is bad..... before I buy a new bomb
RobComment
I recondition them here in the USA (only one that does this afaik) but can't guarantee the check valve, only the nitrogen charge.Originally posted by audimanNew ones aint cheap. 280+vat retail and the servo is around 600 quid!!!!!!!!!
I need to build a whole other rig to check the check valve and the little bit of profit will not cover the cost of it.
A hard pedal is usually the bomb...
BTW, I sell receonditioned bombs for $79.Dave K.
USA
1991 e//S2 (home built S2 - the only way to get one in USA!)
2001 S4Comment
