Thank you. Here is the latest in the saga:
The mechanic checked that he had refurbished the tandem vane pump correctly with new seals and x-plugs. In fact, the lower of the two x-plugs was so tight it could not be removed. The upper of the two x-plugs was removed with its old o-ring and replaced with a new x-plug and o-ring covered in green hydraulic fluid. The internal seals were replaced, except for the o-ring attached to the x-plug that could not be removed. There was some corrosion between the high and low pressure parts of the pump but that was removed / scrubbed away. The seal at the very front of the pump was not removed or replaced.
I was told that the rock hard brake pedal had been caused by the hydraulic fluid system not having finished self-bleeding. It did so somehow and the mechanic road tested the RS2 for 3 miles without incident. I collected the RS2 from the mechanic yesterday evening. All seemed fine, the green hydraulic fluid level in the reservoir was at the maximum line, the brake pedal was normal and the power steering worked.
8 miles into my journey home, the red (!) came on, accompanied by the beeping warning sound. It went off and on over a few miles and then the red (!) remained on. 25 miles into my journey, I felt the steering get harder and the pump started to make an unpleasant noise. The brake pedal was fine. It was difficult to park the car at home with no power steering.
I immediately called the mechanic, who thought that the system must have self-bled on the journey, lowering the hydraulic fluid level in the reservoir. He asked me to check the hydraulic fluid level in the reservoir. Empty. So, I called the mechanic and to his great credit, he drove to me late yesterday evening with more green hydraulic fluid to fill the reservoir.
As soon as the mechanic inspected the pump, it became clear that it was leaking worse than before. It was leaking from the new upper x-plug / o-ring. The reservoir was then refilled to above the maximum with new green hydraulic fluid (above the maximum to account for bleeding). The mechanic removed parts from the car to get to the x-plug, removed the new leaking x-plug and o-ring with the pump in situ and replaced them with a second new x-plug and new o-ring coated in new green hydraulic fluid.
After running the engine, there was no leak from the latest x-plug and o-ring. We took the RS2 for a 15-mile drive. The brake pedal was quite hard. OK at each each first application of brakes but harder on each second or subsequent application. After returning and checking the area around the pump, it was evident that there was no leak from the latest x-plug and o-ring. However, the hydraulic fluid was still above the maximum in the reservoir and the brake pedal was still quite hard. I was told the system needs to self-bleed more.
So, optimistic scenario: the system will self bleed and all is now fine. Pessimistic scenario: the issue has not been fixed and at some point there will be another hydraulic fluid leak, draining the hydraulic fluid reservoir.
I have the following questions:
1. Which company made the tandem vane pump?
2. Where can I get a new tandem vane pump of equivalent quality to a new one from Audi at a reasonable price, given that Audi's price is around £1,100, Audi don't have them and "on back order" at Audi could mean anything.
3. If I wanted a gearbox rebuilt, I would take it to a company who specialises in rebuilding gearboxes. Which companies specialise in rebuilding tandem vane pumps to a very high standard?
4. Do I stick with my existing tandem vane pump or do I need to buy a new one for peace of mind and to end the saga?
5. What happens if the hydraulic fluid level is above the maximum in the hydraulic fluid reservoir and there is no more air to expel by self-bleeding?
Many thanks.
Many thanks.
