So, sick n' tired of the bleeding pump and bomb. Just realized that the A4/S4/RS4 has a vaccum assisted brake servo system that relys on a electric pump. Hooking it up should be....Easy? There is some kind of control unit hooked up to this pump. What does this ECU do? What signals does it read? Is the pup running all the time?
Parts list:
-Electric vacuum pump A4/S4/?? (salvage yard?)
-Brake servo 80 2.8 (?) (salvage yard?)
-Control unit A4/S4 (salvage yard?)
-Sensors?
-Tubing
-Pump for steering, A4 100bar
-Master cylinder Audi 80 2.8
Should be cheaper than the bomb+pump (I'm hoping) which I need to buy to fix my system.
Only problem as I see it - hooking up the ECU and fitting sensors or what not.
Or should I just leave it alone? How boring is that?
Parts list:
-Sensors?
-Tubing
