Hydraulic to vacuum servo conversion
Imola B6 S4 AvantComment
I too have messed with my PAS pressure line and mine does make a whine when turning the wheel, it is not very loud but noticeable.
I am sure, the 30 degree angle means nothing other than making sure the hose is attached to the rack in an unstressed position.
I am also sure that the loop on the rack end means nothing as the very early 7As do not have this, the hose is fitted via a compression fitting to the side of the rotary pump on the rack.
I have a pressure bypass valve in my pressure line to adjust the steering assistance, I can turn the pressure right down, the noise does not alter. So it is not pressure related. The noise is heard as the steering is turned, but not when left still, therefore I am sure it is flow related as the pump supplies fluid on demand to the rack.Panthero Coupé quattro 20vt
As far as I understand it there is negligible flow when the steering is stationary. The pump pressure is controlled by an internal relief valve, so when flow demand is reduced at the rack pressure is relieved at the pump. Pressure remains pretty constant upstream of the rack, due to the relief valve. Flow alters in line with demand from the rack
i see,
the facts are though that 2 of us have the OEM hose changed with noise coming up, and when the OEM is used in any configuration the noise is less. I am not sure why 7A engine has no loop, but it may be that the designated pump has less bar pressure(some are 100, some 75) and that may have something to do with it.
I will have the hose changed and report back.Comment
As promised - pic's of the "damper" lump. I think I got a little les noise when I mounted it, but it can be a placebo effect.
Also you can see the fitting on the pump-to-bomb hose. There was a similar fitting on the pump-to-rack hose.Cheers, Torben
'94 B4 Avant S2Comment
Didn't see any - don't think so. I think I once checked Akte without luck. It looks VAG enough, though. It came off a '92 2,3E (NG)Cheers, Torben
