Well with the signal, there is always a question what fails.
There are multiple circuits on the VSS line and it's just a question of what fails exactly and at which point inside the speedo.
If the rear diff lock still works, then the VSS should definitely be alright.
So the cruise control not working is probably something else. Usual suspects are cold solder joints in the cruise control unit.
