HID Fitting & Earthing
This is a sticky topic.
  • nigelm
    • 150
    Earthing
    This bit was my main question originally.
    I suppose you can't argue against the fact that removing the paint will always give a better contact - if it's not necessary I'd rather not though.
    nigelm
      I know it's standard requirement, but i just used a large ring connector to the body and i get no autocheck problems
      • merlin's S4
        • Jan 2005
        • 1539
        Once you've drilled a hole somewhere and tapped a screw into the metal you will have a bare metal earth connection where it's screwed in, as long as the earth cable is connected to the screw well enough (ie with ring connector). Obviously removing a small amount of paint where the ring connector sits will ensure you get a good earth but it's probably not always necessary!
        • Ski
          • 2591
          I still need to get around to fitting mine
          ABY Coupe
          • s2_bo
            • Oct 2005
            • 6067
            #20
            Mine are not earthed properly yet resulting in flickering when you use the windscreen washers while the lights are on.. i doubt that can do the bulbs and blasters any good.
            I earthed them trough the cables on the blasters. This is what the instructions said but its obviously not good enough.
            91 S2 coupé - RIP
            98 S8 - Luxury barge
              • 12431
              Here is the thread from Guides & Top Tips about fixing the autocheck problem with HID lights
