I picked up my 1st quattro last week.i have a niggling problem,everytime i brake the bulb light alarm bleeps at me,but everything is working ok.
I changed all the bulbs just incase and now the warning light is permantly on.
Any help would be appreciated.
If it is not low brake fluid or low hydrolic fluid, it could be the bomb (pressure accumulator) on its way out and not holding pressure, or if you are unlucky it could be the PAS pump not generating enough pressure.
