Probably asked a load of times, but I'm stressed and lazy in equal measure, I'll keep looking after I've posted this.
Today my 96 S6 started dropping power completely, then bursting back into life, then dropping, then going so I thought I'd switch it off and on again as a first port of call, only it didn't switch back on again...
I thought fuel pump relay but swapped for a known working one to no avail, fuel pump gets power when cranking (though doesn't seem to prime? Not sure it's meant to?) and makes pumpy noises when cranking and carries on a little after you stop cranking.
So moved to engine bay to find no spark at the plugs. Unplugged/replugged everything in the immediate coil area still no joy but that's where I concluded my investigation because I was getting hangry.
The only thing I've changed between perfect working condition and this is fill the tank with super unleaded.
Any ideas where to start with it tomorrow?
edit - turns over healthy as a horse, plugs were dry so no fuel either I guess...
