Well thanks to parts daddy and 4wheeldrifter the Avant is running smoothly ( for the moment ) after a mini vag-com and test drive session.
After a bit of heading scratching and reviw of the wiring diagram by the "daddy" a cure was found.
The cause of the problem? only 2 missing 10 amp fuses from position 24 and 25 for some of the sensors in the car including the lambda sensor (returned value 1 fulltime, explains the rich running at the RR), ISV, WGFV, Charcoal Filter etc etc.
Parts Daddy nearly fell of the chair when he saw the amount of fault codes my car pulled back
No more 1k idle now a nice 700 rpm and no unburnt petrol being put out the exhaust.
No doubt there will be post of the codes from the above as quote "gotta get that up on the forum
2nd S2 i've owned now thats had missing fuses or relays so worth having a check for peace of mind folks.
"2nd S2 i've owned now thats had missing fuses or relays so worth having a check for peace of mind folks.
. I have replaced it so hopefully all will be well for a while
