Fuse box connections on underside
  • Fuse box connections on underside
    I stupidly removed the fuse box without noting the terminals on connector M. These are single wire connections for electric windows/AC/central locking etc.
    Does anyone have a picture of the underside of the fusebox, with the cables attached?
    I have checked at info on S2central and it is only shown for the ABY engine wiring. nothing is mentioned about these connections.
    Tom C - www.rcmr.co.uk
    Audi UR Quattro
    Audi 100 C3 2.0 5 cyl 115ps
    Audi B5 RS4 645ps 911nm
    Does this help?
      Yeah - I have seen these pictures. It’s the individual connections on block M. They are all separate terminals. They are the only ones I didn’t get a picture of FFS!
      30ac i know as that’s for ecu fuse
      the rest I have no clue, one is for mirrors, one for Windows, one for rear wiper and there as a couple of others too
      also does anything go on 87k?!
      Audi UR Quattro
        My dash is still off. I had a quick look for you just now but its all spaghetti in there and I cant even see the bottom of the fuse box! I can have another look tomorrow if you like and try and move some wires to get a view. My car is ABY. Make any difference?
          Going through the 3B wiring diagrams page by page and looking for any connections to the fuse box that start with M, I get this:
          M75s. Black / grey. Fog lights
          M30ac. Red/blk. After run pump
          M75ak. Black/blue. Air blower / fag lighter
          M75s. Black/blue. Electric windows
          M30az. Red/black. Heated door locks
          M75as. Red/blue x 2. Electric mirrors / window wiper rear
            M30ac also appears to power the black OBD connector (fuse21)
              That would be very helpful if you can, you may need to move the bundle of cables out of the way to see them. The connections are on the side of the fuse box closest to the centre of the car.
              Audi UR Quattro
                Thanks John, I have found a couple of them. I will take another look in the morning. Had to walk away tonight.
                Spent hours removing the old Clifford alarm that had stopped working. The wiring was such a mess.
                Audi UR Quattro
                  It's from. A lhd but maby it will help
                  Gesendet von meinem EML-L29 mit Tapatalk
                    ****** perfect!!! Great pics, that will get it done
                    Audi UR Quattro
                      Cool
                      I was struggling
                        I took a few pics of mine before I removed think I have messed up with the red L connectors. Let me know if you need more pics
                          Doesn’t matter where they all go, as it is all just battery live (terminal 30).
                          Audi UR Quattro
