Headlight bulbs
  • Nap51dcrow
    • Apr 2020
    • 7
    • Home: United States Current: United Kingdom
    #61
    As mentioned, low beams, City lights, and side marker turn signal all LED
    This gallery has 2 photos.
    • quattro estate
      • Aug 2015
      • 190
      Hi. You need to add a resistor for each headlight, I only paid a £5 after complaining to the headlight bulb supplier about the warning light staying on
      • quattro estate
        • Aug 2015
        • 190
        • Nap51dcrow
          • Apr 2020
          • 7
          #64
          Do you have any info about the resistor they supplied? Or did you send them the bulbs back?
          • quattro estate
            • Aug 2015
            • 190
            They were standard resistors or ballast as sometimes called. Where ever you buy them just tell them what you need them for
            there is no info on the ones I fitted
            • Nap51dcrow
              • Apr 2020
              • 7
              #66
              You mean this thing?
              This gallery has 1 photos.
              • Nap51dcrow
                • Apr 2020
                • 7
                #67
                Also, may I ask how you did the wiring? Maybe I screwed up?
                • quattro estate
                  • Aug 2015
                  • 190
                  Yes that looks like the resistor
                  you wire in the unit inline
                  Cut Each live wire going to each bulb and fit the unit inline with the 2 wires on the unit, so re joining the live wire end with unit in between
                  hope that makes sense
                  • Nap51dcrow
                    • Apr 2020
                    • 7
                    #69
                    There is only 1 wire going into my factory headlight bulb. It is an H1 bulb. I emailed the company, waiting on a reply.
                    • quattro estate
                      • Aug 2015
                      • 190
                      Yes just 1 wire to each bulb
                      join in the unit after cutting the wire
                      1 unit to each bulb
                      • John.
                        • 2615
                        Originally posted by Tom_
                        Headlight assembled. Looks much better, will see how it works in the night.
                        That looks goooood !
                        • quattro estate
                          • Aug 2015
                          • 190
                          Hopefully a success
                          let me know where you are
