RS2 battery box dimensions
  • PRY4SNO
    • 767
    Does anyone happen to have the dimensions of the battery box from an RS2?
    2013 Touareg TDI /// #farmenwagen
  • Mr G
    • Jun 2008
    • 196
    • Country: South Africa
    Did the RS2 have a battery box? I thought it was just the tray and "clamp" to hold the battery in place - I could be wrong
    • PRY4SNO
      • 767
      Wasn't it under the rear seat in a box?
      I think the B2 80q (4000q in N. America) also had it but can't recall.
        • Dec 2017
        • 6006
        No, as stated RS2 and S2 Avant have the battery in the nearside of the boot. It's just a tray that sits in there with two or three bolts holding it in. I did remove one recently and had pics on my phone but they are gone now
          The ABY coupe and the Ur quattro have the battery under the rear seat.
          I moved the battery in my 3B coupe from the engine compartment to under the rear bench using a battery box cut from an ABY.
          I still have the template for cutting the floor.
          I could make you a copy or take a pic with a ruler in to scale from.
          The Ur quattro battery box is a little bigger from memory, I could check if you need.
          • _ShurikeN
            • Mar 2010
            • 733
            • Country: Russian Federation
            Any useful dimensions helping to point exact place would be appreciated.
            Wanting to start, afraid to grind in wrong place.
              Assuming you’re converting a 3B or a CQ. Coupe!
                I used this template to cut my floor.
                The two horizontal marks line up with a step in the floor, the ABY box is made to fit this step. That sets your position forwards and back.
                The tiles on my work top are 6” inches plus the grout, call it 6 1/8th.
                Can’t remember what the two marks are at the top left, probably a feature in the floor.
                You have to re-route the fuel lines and fuel filter under this area, don’t start cutting without looking underneath
                  I found a couple of pics that I used at the time to work out the position.
                  You may find more pics on the forum because I know I documented it at the time, I’ve had a look but the search function doesn’t seem to work like it used to..
                  It’s mentioned in my 3B project thread but the pics are not there.
                    • PRY4SNO
                      • 767
                      Didn't realize there were different sizes, that's awesome to know. Thanks for the model confirmation guys.
                      And newsh, thanks a million for the pics. That's very helpful. I am interested in the dimensions of the box if you're able to oblige.
                        The outer dims are as you see on the template, I can’t tell you the depth as my car is not here at the mo.
                        If you want to do this conversion the best thing would be to get a battery box from a scrap car. You will then have the complicated shape of the top to match the step and the details in the floor and the battery clamp and ground tag.
                        • jeffstoo
                          • Apr 2011
                          • 98
                          These pictures may help, from resiting the battery in my 3B. I couldn't get hold of an ABY one at the time so I made one. I used pictures and guesswork and luckily it all worked out.
                            Well done, good work
                              Amazingly it’s available
                              Part no. 895803901
