Speedo problem
  • Jamesey
    • Aug 2021
    • 154
    Speedo problem
    Hi I've got a Duff speedo head where the mileage won't click around and I don't want to strip it to fit the cog incase I break the needle.
    also my trip computer has bled so that's unreadable aswell .
    I've been offered a replacement head but he tells me the fuel and temp gauges don't work and it needs soldering....anyone had this before
  • Bowie69
    • Nov 2013
    • 2676
    Needle is quite robust, just follow the instructions.
    LCD panel can be changed, group buy forming on this forum somewhere.
      • Dec 2017
      • 6006
      Putting new cogs in is quite easy. You get them from partworks.de
      • Jamesey
        • Aug 2021
        • 154
        Any ideas who can change this please ?
        • Bowie69
          • Nov 2013
          • 2676
          You can do it!
          • Jamesey
            • Aug 2021
            • 154
            Cheers mate ?
            • steve briance
              • Aug 2014
              • 1455
              Any working secondhand speedo will come with second hand cogs. How long would you be pleased with having a working speedo before the replacement goes the same way? Ive learnt short cuts never actually save time.
              Get a cog and follow the instructions about removing needle. I found spinning mine off much more successful than prising it off.
              Spin it all the way to the stop and keep going but, as you spin pull a little. It will work its way off with no damage.
              • Bowie69
                • Nov 2013
                • 2676
                Yep, twist and pull
                  I’ve repaired a lot of these, trip computers, Odometer cogs, resoldering stuff.
