ABY Factory Immobiliser Advice
  • Mikes2
    • 1704
    I take it you have checked all your other fuses ? S21 will stop your diagnostics working.S27,28,32 will all stop your engine firing up
    Mike
    http://www.s2-audi.co.uk
    • oollit
      • Aug 2021
      • 41
      Yes I have removed, checked and cleaned up all the fuses.
        I’ve seen a pin pushed back in the ECU connector before, worth checking.
        Otherwise there may be a clue here..
        • oollit
          • Aug 2021
          • 41
          All the injector earths have good continuity and the pins in the ECU and terminals in connector look fine.
          I am starting to think it must be an ECU problem, both the origonal and the replacement ECU's must have a similar problem as I cannot see any other reason as to why the car won't start.
          • Bowie69
            • Nov 2013
            • 2680
            Will it run with a slug of easy start shoved down its throat?
            • oollit
              • Aug 2021
              • 41
              yes it will fire with a drop of carb cleaner, so ruled out spark a while ago.
