Instrument cluster schematic
  • Antsa
    • Nov 2016
    • 617
    Yes if you are willing to pay to access the erwin system. But the pinouts are listed in the link above
    • Mikes2
      • 1704
      Originally posted by Bowie69
      Most helpful.
      Confused why the heated rear window and a couple of other things go to the dash, but there we are
      I'm pretty sure it's for background lighting. The grey / blue wire supplies lots of circuits to provide ambient lighting and it comes via the dimmer in the cluster.
      Mike
      http://www.s2-audi.co.uk
        • Dec 2017
        • 6006
        Nearly there.
        • Rikki Kitto
          • Feb 2010
          • 6276
          Are you thinking of offering a cluster repair service
            • Dec 2017
            • 6006
            Done
            I have no way of testing the Rev counter or speedo but I can get just about everything else working on the bench which is very handy.
              • Dec 2017
              • 6006
              Of course
              • Rikki Kitto
                • Feb 2010
                • 6276
                Ace news I'll be your first customer I have a spare set that will need checking over and a new lcd screen fitting which I have already bought
                  • Dec 2017
                  • 6006
                  Ok, no problem. Send me a pm. I've just done the LCD successfully on the Coupe. Happy to talk you through it. It's not too difficult or if you are nervous, I can do for you.
                  • Bowie69
                    • Nov 2013
                    • 2680
                    For speed and rev counter, you just need a variable voltage power supply, cheap enough on ebay.
                    Whilst they are supplied pulses, they effectively average the voltage using a capacitor.
                      • Dec 2017
                      • 6006
                      I understood from Paul Newgents post on this subject that you needed a pulse from oscilloscope or similar
                      I haven't managed to get the fuel or temp gauges to move either. I'm nervous about connecting some of the brown and coloured wires to positive (as indicated in the guide) as Audi tend to use brown for negative and I don't want a short. I've found one error in the guide so don't want to take any chances.
                      My aim here was just to test all the bulbs on the bench.
                      • pfi
                        • Jun 2016
                        • 274
                        • Country: Norway
                        #26
                        check : http://coupe.gofergusons.org/gauge_repair.htm
                        used info here when fixing mine ...
                          • Dec 2017
                          • 6006
                          Yes, seen that and very handy
                          • Bowie69
                            • Nov 2013
                            • 2680
                            In testing my speedo a while back, I just supplied 12v to the vss pin and the need swung round smoothly.
                            If you remove the motor, then you can apply power in either direction as as motor doesn't care a jot
                            Wiring colours on the wiring diagram are good to work out what needs neg and what needs pos.
                            • pfi
                              • Jun 2016
                              • 274
                              • Country: Norway
                              #29
                              Some notes I did when testing :
                              - speedo test :
                              T26a / 16 : Plus Spannungskonstanter, Tacho
                              T26a / 18 : Tachosignal Ausgang not needed for test
                              T26a / 20 : Geschwindigkeitssignal Eingang vom Sensor
                              T26a / 21 : negativ
                              Connect T26a/16 and T26a/21, rapid on/off negative-signal on T26a/20 should make the dial-needle to "jump",
                              keep rapid on/off to to confirm trip-counter reaction
                              still no response ? propably an electrical error
                              if needle responds but no reaction on trip, propably the famous gear-problem ...
                              - Drehzahlmesser / Rev counter : T26 (yellow) - T26a (blue)
                              T26 / 21 : minus
                              T26 / 22 : pulse (positive)
                              T26 / 23 : minus (5-cyl) not needed for test
                              T26a / 16 : positive
                              Connect T26/21 and T26a/16, rapid on/off plus-signal on T26/22 should make the dial-needle to "jump",
                              • Mikes2
                                • 1704
                                to get the fuel or temp gauge to move you scan earth the signal wire which will give full scale deflection
                                Mike
