Instrument cluster schematic
    • Dec 2017
    • 6006
    I’ve just discovered that the newer cluster pins don’t wind off.
    • Bowie69
      • Nov 2013
      • 2680
      Do you mean needles? Sorry, confused
        • Dec 2017
        • 6006
        Yes. Speedo needle. Went to wind it back anti clockwise and the whole pin came out with a thin length of spring attached. I’m really annoyed with myself as this was a perfect working cluster from the cabbie with autocheck and fuel computer. I tested it in the s2 and it was fully functional. I was just going to swap the dials for white ones and have it as a spare.
        • Bowie69
          • Nov 2013
          • 2680
          Oh no.... I wonder if someone has been in there before and loctited it on?
          Did the needle twist at all?
            • Dec 2017
            • 6006
            No. The cluster hasn't been opened before. It was still factory sealed. I did read a thread here somewhere that the needles can't be removed on later clusters and this is a 10\95 build.
            I will unsolder the stepper motor and see if I can get another.
