UrS6 Plus Radio Remote Conversion
  • afen
    • Aug 2011
    • 112
    • Country: Norway
    I have an UrS6 Plus with the non-functioning IR remote and the 4A0862257J central locking pump. I'm looking to fit a 8L0862257G pump, but there are some differences between the units. There is a T10 connector instead of the T6, and the 8L0862257G pump has dual vacuum ports.
    Is there any way to convert from a 4A0862257J to a 8L0862257G pump, or are there any alternative pumps with radio remote control that I can use?
  • afen
    • Aug 2011
    • 112
    • Country: Norway
    Is there a possibility to use the 4A0971014 adapter harness from a 4A0862257P pump to fit the 8L0862257G pump?
    • struikie
      • May 2019
      • 315
      I swapped a non remote pump in a B5 to a 8L0 pump years ago, added a picture of the diagram from my archives.
      A quick interweb search gave this:
      http://www.ts85.de/a3fshare/uploads/...e_mit_Funk.pdf
      https://www.a4-freunde.com/showwiki....ng+Pinbelegung
      What I bought back then according to an excel file:
      8L0 862 257 D - pump
      4B0 837 246 A INB - key with transponder
      4D0 837 231 R 01C - remote
      000 979 018 - repair wire (I think this was for being the antenna)
      N 024 522 3 - hose clamp
      JW
      | project | 1993 Audi 80 VR6 turbo quattro |
      | daily | 2018 BMW G31 530d | 345bhp 770Nm |
      • struikie
        • May 2019
        • 315
        The diagram doesn't seem to be the one you need hahaha
        JW
        • mdz
          • Jun 2012
          • 775
          • Country: Latvia
          • afen
            • Aug 2011
            • 112
            • Country: Norway
            I believe that the B5s have the new type of wiring with the T10 connector, but I have the old T6 connector. Might just be a lot easier to get a remote system from Rightclick.
