I have a non-functioning courtesy light and rear windscreen washer in the boot of the one of the S2 Coupes. I have measured the connectors with everything disconnected and there is 12V present when required, but when the load (bulb or washer motor) is connected they don't work. I have checked and measured a resistance to a good earth of around 20 ohm on the earth connection to each device which explains the issue
Q. Is there a common ground point within the Coupe boot where these wires connect to and if so where is it? I suspect it all just needs a good clean.
I could just connect the light and washer motor to a good local earth but I would rather fix it properly and use the original wiring.
