With the wire connected, does the factory immo horn (H8) honk when you lock the car ? It should... If it doesn't then maybe its short circuited - which trips up the central locking pump (V94) which also operates as the anti-theft alarm
Central Locking Electrics
It should 'honk' alright.Paul Nugent
Do remember the standard alarm only alarms if you turn the key in the lock.
If you have an aftermarket alarm and using the keyfob of that to lock and unlock it wont activate the alarm.
Well it doesn't on my Avant ( and I have a thread to prove it and my car has been banned from my local garage
The factory alarm is V94 - the central locking pump...
Good point Jamo about the key setting the alarm - unless car has factory or aftermarket infrared/radio remote control linked to V94... I bought the VAGparts remote control - integrates with V94 like factory system... When I lock the car with key or keyfob then I get the little 'honk' from H8.
PaulPaul Nugent
