Indicator/Hazard problem?
  • stevieyid
    • Apr 2005
    • 2251
    On my way home otnight and i indicated right to turn into my drive and the Hazard lights come on Pulled into my drive and had a fiddle about but still the hazard lights come on when i indicate. Any ideas on what it could be?
    3'' Longlife Exhaust, Koni Adjustables, H&R Springs, Full RS2 Setup with Mr Nugents RS2 Chips (just need the RS2 Airbox)
    probably the contacts in the stalk i'd say
    • Acidburn
      • 13459
      or loose pins in the back of the plug.
      • nip
        • Apr 2006
        • 1786
        • Home: United Kingdom Current: Abu Dhabi
        if its your s4, i think its the same as vw passats, the flasher unit is built in to the back of the hazzard switch so id recomend changin the hazzard light switch to see if it cures the problem, hope this helps
        • stevieyid
          • Apr 2005
          • 2251
          Hi nip, thanks for the reply i dont have the s4 anymore i have an s2 again now. How do i access the plug and the contacts on the stalk?
          • nip
            • Apr 2006
            • 1786
            ur welcome mate, u have to remove the coulin under the steering wheel, not too sure if u remove the wheel itself dont think u do. Theres 2 screws to undo for the steerin boss then ya should be able to get to the plugs mate
            • Nj
              • Jan 2007
              • 3420
              • Home: Scotland Current: Finland
              could it be disco lights? Just a thought as an alternative. disco lights being corroded light boards in your rear lights. I had indicator/hazzard/brake lights shenanigans and it was just the boards.
              1990 CQ20v
              • stevieyid
                • Apr 2005
                • 2251
                ill check the rear boards. If it was the rear boards would it still affect the front indicators to as they both come on when i indicate
                • stevieyid
                  • Apr 2005
                  • 2251
                  Just checked the connections of the stalk everything seems to be tight and no lose wires. Checked the rear boards they do look a little corroded and have seen better days. Where can i get a new set and how much am i looking at?
                  • Nj
                    • Jan 2007
                    • 3420
                    i'll check the set I have on the coupe in my garage and let you know if they're decent mate.
                    1990 CQ20v
                    • stevieyid
                      • Apr 2005
                      • 2251
                      thanks mate that would be great. At least i can eliminate them as a cause. When i took the coulin off there was 2 stickers on the bit where the plugs plugged into. What are they and could they be the cause?
                      • stevieyid
                        • Apr 2005
                        • 2251
                        Checked all the plugs and wires again today but still no change. Both indicators on when i turn right or left!!! Really annoying any ideas?
                          Have you actually replaced the stalk yet?
                          • stevieyid
                            • Apr 2005
                            • 2251
                            No not replaced the stalk, as it only started happening a couple of days back. Whats involved in replacing the stalk
                              Steering wheel off to get to the screws.
