Hi guys,
I have a 1993 aby model s2 and its got an electrical problem, Its going through coils at an alarming rate ( current set 11 months old ) and Im hoping someone out there can help.
The car is superchipped but otherwise standard, there is a missfire at 3000 rpm then a bigger missfire at 5000 rpm, fitted three new coils today supplied by euro car parts, but the problem is still there. any ideas?
they are some trublemakers
sometimes they are ok,sometimes NOT.kontrol the unit,and see if you get at least 12volt at the unit,you may have ground(-) problem too. 14,4-14,7volts are ok with the battery......
