ignition coil problem
  • Ian C
    • Aug 2004
    • 4
    Hi guys,
    I have a 1993 aby model s2 and its got an electrical problem, Its going through coils at an alarming rate ( current set 11 months old ) and Im hoping someone out there can help.
    The car is superchipped but otherwise standard, there is a missfire at 3000 rpm then a bigger missfire at 5000 rpm, fitted three new coils today supplied by euro car parts, but the problem is still there. any ideas?
  • Anees786
    • Jul 2004
    • 85
    hiya mate did u change the actual coils or the coil plugs as well ?
    • Ian C
      • Aug 2004
      • 4
      New spark plugs and coils mate, got the car originally with the coil problem and fitted the new bits and It ran fine, less than 8000 miles later the problems back.
      • shadquattro
        • 263
        • Home: England Current: Scotland
        i have a similar problem and have changed several coil packs and an ignition amplifier in mine when i get the next one i am hoping thats it
        skint but fast
        • caterpillar
          • 2480
          Originally posted by Ian C
          Hi guys,
          changed the IGNITIONSWITCH they are some trublemakers sometimes they are ok,sometimes NOT.kontrol the unit,and see if you get at least 12volt at the unit,you may have ground(-) problem too. 14,4-14,7volts are ok with the battery......
          • Ian C
            • Aug 2004
            • 4
            Would the ignition switch fault not show up in the brain scan?
            • caterpillar
              • 2480
              If you have sometimes BAD connections it will NOT show up. it means sometimes you have only 7volt out to the coilpackage,then you burn the coilkit
              • Ian C
                • Aug 2004
                • 4
                Thak you.
                Thank you for your wisdom Caterpillar, I will investigate.....
