hi guy's
my rs2 was working fine this morning until i switch off the ignition,then notice all the lights went out including radio.normally the radio plays without ignition on,now i have no ignition or any electrical power coming through when i turn the key
.so car now will not start.i have checked the battery and it seem to have full power.
the question is does these cars have a ignition module if so where about is it located?
could it be something like bad earthing?
fuse?
any imput to get to the problem is welcome
.so car now will not start.i have checked the battery and it seem to have full power.the question is does these cars have a ignition module if so where about is it located?
fuse?
You need to do a lot of reading about your RS2.
