As per title since ripping the alarm out of the car the battery is being drained overnight
i can't pin it down to where the drain is coming from is there a simple way to check if there is power being taken from the battery. All the interior lights are switched off . What in the car could drain the battery overnight the battery is new and i checked the battery with a voltage gauge and it showed 10 amps and the needle held without dropping. Need to sort out as it's my daily.
